Opening Wall Under Stairway
jmshepherd
I am looking to open up under stairway.  How do I cut the wall out to follow the bottom of the stairway.  At this point Im using a doorway without casing or jamb, if I could reshape this doorway top, that would be the answer.    I dont want to expose the stairway.
1 hour ago, jmshepherd said:
I’m taking by the silence this is not possible with this software?
Last time I looked, there was no signature and no picture. When you edit a post, like to add a picture, it does not show up in the forum as changed.
Anyway, see if this helps.
You can check for program updated via the Help menu.
But I don't believe that's the problem. And you don't need to use a Pony Wall. That's just one way to cover the bottom of the wall. You could use a Sloped Soffit, or just use a wall that's solid drywall like I show.
