guesthouse Posted February 12, 2021 Share Posted February 12, 2021 (edited) I have Designer Pro 2021. I am creating the plans for building a guest house. I am trying to figure out how to draw the roof. The building is basically 3 rectangles side by side with the short ends to the front. The center rectangle should be about 4' higher than the other 2. Its roof will be a low slop with a center hip shedding water right and left on to the adjacent 2 rectangles. The front wall of the center section will be flat across the top about 1' higher than the hip so the entire roof line is hidden from the front. Then for the rectangles on the right and left of the center section, they will be low slopes running right and left respectively. Both of these walls will be hidden from front view by a low flat topped wall. Can anyone tell me how to do this. Edited February 13, 2021 by guesthouse added layout and photo Link to comment Share on other sites More sharing options...
solver Posted February 12, 2021 Share Posted February 12, 2021 11 minutes ago, guesthouse said: Can anyone tell me how to do this. No idea what you want to do. Give it your best effort, then post a couple of screen captures so we have something to discuss. Link to comment Share on other sites More sharing options...
