Kenster Posted February 1, 2021 Share Posted February 1, 2021 Hi, I am making progress with my designs as a new user since Nov 2020 but on occasion run into an issue that I may be able to find a hack to solve it but looking to work towards better design skills realizing this will take time. Attached is a simple house I am working on where I have added a future sunroom on to the end of the house. I have managed to sort out the roof lines as I require but as you can see the wall does not fill in just below the new roof. Is there a way to tell the program how to fill in the gap? Or this is a case where I need to use a back splash or draw a polyline then add a fill style. I am just guessing as to how the pros would handle this. Thanks in advance, Ken Link to comment Share on other sites More sharing options...
solver Posted February 1, 2021 Share Posted February 1, 2021 That should automatically fill in. Go to the 2nd floor and make sure there are no walls marked as invisible. Attach the plan file if you cannot get it working. (close the program first) Link to comment Share on other sites More sharing options...
Kenster Posted February 1, 2021 Author Share Posted February 1, 2021 Exactly what I was hoping for the correct way to adjust this. I did in fact build the second floor based on the first and then pulled back the wall covering the sunroom to the main house and yes there were dotted line walls present marked as invisible. Thanks. Link to comment Share on other sites More sharing options...
