Cannot Hide Saved Camera Icons in Plan View
JHBaglien
Using Home Designer Pro.  In "layer dsplay options" the cameras are marked with an "S" in the "used" column and I think it should be an "X".  How do you turn the S into and X? I believe this is why the saved cameras will not hide in plan view. when I iuncheck the "displ" column the camera icon do not hide on the plan.
If i open a new plan, draw something, then open and save a camera, I can go into display and uncheck the camera andj it disapears.   So, it does work. just not on the plan I have been working on.   Also, there is an "X" in the "used" column in display, unlike on my problem plan which shows an "S".
