blackbeard Posted January 18, 2021 Share Posted January 18, 2021 Just started using HD Pro 2021 this month and run into a perplexing problem. A standard Cape Cod structure with gabled east west ends. Full wrap around porch. (See Plan View 1). In 3D view, the east west ends are no longer gabled. See 3D View 1. The east west walls still indicate full gable. See Wall - Roof Dialog View 1. How can this be corrected? Kevin Kilpatrick Home Designer Pro 2021 Link to comment Share on other sites More sharing options...
solver Posted January 18, 2021 Share Posted January 18, 2021 How did you build the porch roof? Link to comment Share on other sites More sharing options...
blackbeard Posted January 18, 2021 Author Share Posted January 18, 2021 Selected each outside railing segment, Railing specification dialog box, Roof dialog box, clicked on Hip Wall; Pitch = 3"; checked Upper Pitch; Upper Pitch = 10"; In From Baseline = 98"; the rest as default. Kevin Kilpatrick Home Designer Pro, 2021 Link to comment Share on other sites More sharing options...
solver Posted January 18, 2021 Share Posted January 18, 2021 So do you understand why you are getting all hips? It's what you told the program to build. Link to comment Share on other sites More sharing options...
blackbeard Posted January 19, 2021 Author Share Posted January 19, 2021 I had tried the dutch gable approach but didn't understand that I could alter the lower pitch to 3". Thank you so very much for your kind assistance. Kevin Kilpatrick Link to comment Share on other sites More sharing options...
