HomeProNon Posted January 12, 2021 Share Posted January 12, 2021 Library does not contain slump block. How can I modify a wall material (CMU 8" block) to a 4X8X16? Essentially I just need to cut the size of the CMU height to 4". Link to comment Share on other sites More sharing options...
solver Posted January 12, 2021 Share Posted January 12, 2021 3 minutes ago, HomeProNon said: How can I modify a wall material (CMU 8" block) to a 4X8X16? Change the material. Read about materials in Help. Link to comment Share on other sites More sharing options...
HomeProNon Posted January 13, 2021 Author Share Posted January 13, 2021 Thanks for the help. I am using using Home Designer Pro 2021 version. Not sure if using a Mac makes a difference. have gone through a number of tutorials and help options, but not finding exactly how to re-dimension an existing material or creating a new one from scratch. I will try the YouTube link. Am relatively new user, so appreciate the basics. Link to comment Share on other sites More sharing options...
solver Posted January 13, 2021 Share Posted January 13, 2021 Textures, like the block you are asking about are simply image files that are tiled over an object. The image may be stretched or compressed in the X and Y direction to change its appearance. Link to comment Share on other sites More sharing options...
HomeProNon Posted January 13, 2021 Author Share Posted January 13, 2021 Have figured out how to create the 4" block and applied to a sample wall. Now on to getting on my project walls. Thanks for the help. Al Link to comment Share on other sites More sharing options...
