camley88 Posted December 24, 2020 Share Posted December 24, 2020 I can't figure out to get rid of the thin wall issue in the first photo below without having the two cross hatched walls in the second photo intersect. If I drag the selected wall in photo 2 down and unconnect it from the other exterior wall, the problem goes away but I create a break in my exterior wall. Any ideas how to fix this? Link to comment Share on other sites More sharing options...
solver Posted December 24, 2020 Share Posted December 24, 2020 Probably related to how the walls are defined. If you just want to clean up the 3D visual, I'd patch it with a soffit, or even a Custom Backsplash set to Cut Finish Layers. Link to comment Share on other sites More sharing options...
camley88 Posted December 24, 2020 Author Share Posted December 24, 2020 Custom Backsplash was very creative solution that worked perfectly. Thanks for the tip Eric Link to comment Share on other sites More sharing options...
