help me with picture please
banditz
The most usual way is two-fold:
1. Open “Edit – Default Settings – Walls” and set the interior material to your exterior walls interior side and set your interior wall outer layers to the intended material.
2. Then go to “Edit – Default Settings – Materials” and in the “Materials dialog – Interior Walls” set your intended material to the default “drywall” layers.
Then when you draw exterior and interior walls, they will have been pre-programmed by you to display the interior materials of your choice.
There are numerous ways to alter materials but for walls, this is the recommended method.
please guide me with picture how to do this tutorial ...
Untitled 1.plan
