belmont Posted October 14, 2020 Share Posted October 14, 2020 How do I layout an octagonal floor plan with the walls all being equal length? When I draw out the desired plan, the walls all change length, and If I manually adjust the length, it shortens or lengthens the joining wall. I am using Home Designer PRO 19. Link to comment Share on other sites More sharing options...
solver Posted October 14, 2020 Share Posted October 14, 2020 The easiest way is to Build>Railing and Deck>Polygon Shaped Deck Enter the parameters and create the deck. Open the deck room and change the room type. You can also layout using CAD. Draw lines where you want the exterior main layer of your walls. Walls will easily snap to these lines -- you may need to add some Allowed Angles. Add a center point, draw a single wall, use Transform/Replicate to copy and rotate it about the point. 1 Link to comment Share on other sites More sharing options...
belmont Posted October 14, 2020 Author Share Posted October 14, 2020 Thanks, you really know your stuff! Link to comment Share on other sites More sharing options...
solver Posted October 14, 2020 Share Posted October 14, 2020 Watch on YouTube: http://youtu.be/EtS98ErcCt8?hd=1 Link to comment Share on other sites More sharing options...
