RollieBoy Posted September 29, 2020 Share Posted September 29, 2020 Hi everyone, I am very new in Home Designer Pro 2021. I am placing some cabinets in my kitchen design and wanted to put a customized Backsplash, however my Custom Backsplash Tool bar is Greyed out and not active. I read some help notes and follow the instructions, but it did not fixed the problem. What I noticed is when I click the customise Tool bar I can see the Custom Backsplash Tool bar getting activated, but I cannot used it because the Tool Bar configuration Menu is Open. When I close the Toolbar Configuration Menu, the Custom Backsplash Tool goes Grey again and stay not activated. Any help from you Guys will be very much appreciated. Link to comment Share on other sites More sharing options...
barthmv Posted September 29, 2020 Share Posted September 29, 2020 Custom backsplash can only be done in camera and elevation views. I don't know if you are trying to do it in plan view but you can't, only in camera and elevation views. 1 Link to comment Share on other sites More sharing options...
RollieBoy Posted September 29, 2020 Author Share Posted September 29, 2020 Hi Barthmv, Thanks for your help. As I said I am only new to this software (less than a month) and still learning. I am actually trying to open it in plan view. I just realised it is a vertical direction and needs to be on the wall going up or down. As I read your reply I open the Home Designer Pro and check the Customised Backsplash and it is activated. Again, thank you so much for your help. Link to comment Share on other sites More sharing options...
