ChuckWedel 0 Posted September 10, 2020 I have Home Designer Version 9.0 and I am having trouble creating a shed roof. The plans are for an outbuilding, 24 x 36, with 2 bedrooms and bathroom on the second floor. The gable dormers are on the front (done that), and the bathroom will be in the in the back, under the shed roof. Can anyone help me? You can call me on cell at 703 216 2060. Thanks! Outbuilding - HOLD.plan Share this post Link to post Share on other sites
solver 621 Posted September 10, 2020 *** I see you said Home Designer Version 9.0 *** Answers often depend on which title (Suite, Pro etc) and version (2018, 2019 etc) you are using. You can help everyone by adding that info to your signature (see below for how to turn them on) by clicking on your user name at the top right of the page, click Account Settings, then Signature on the left. Doing so makes it always available, and keeps others from having to hunt for it. And, turn on signature display too. ---- Resources for self help: The built in Help System (always a good place to start) Getting Started Knowledge Base YouTube Home Designer - Getting Started - Setting Preferences and Defaults Watch on YouTube: http://youtu.be/s-TcAHsiMjg?hd=1 Share this post Link to post Share on other sites
ChuckWedel 0 Posted September 10, 2020 Thank you, Solver! I have Home Designer Pro 9.0, and will attempt to add that information to my signature (I am not very technical, as you can tell...). Thanks! Share this post Link to post Share on other sites
solver 621 Posted September 10, 2020 Since you have Pro, why not draw the shed roof manually? Here is a video that may help. Share this post Link to post Share on other sites
ChuckWedel 0 Posted September 10, 2020 Sketcher, I tried to create the shed dormer both manually and automatically,, and I couldn't get either to work... Share this post Link to post Share on other sites
solver 621 Posted September 10, 2020 19 minutes ago, ChuckWedel said: and I couldn't get either to work... What's the problem? Can you attach a screen capture or 2 showing what happens? Share this post Link to post Share on other sites
ChuckWedel 0 Posted September 10, 2020 Here's a photo, shows the roof, but can't get the walls to build. Thoughts? Share this post Link to post Share on other sites
solver 621 Posted September 10, 2020 Did you watch the video referenced above? Share this post Link to post Share on other sites
ChuckWedel 0 Posted September 10, 2020 Yes, but I couldn't follow it, the guy was super fast... Share this post Link to post Share on other sites
solver 621 Posted September 10, 2020 I can't tell from your image, but it looks like there is a roof below your shed roof. You need a hole in the lower roof, or simply move it out of the way. Share this post Link to post Share on other sites
ChuckWedel 0 Posted September 10, 2020 I will try that and let you know - thanks! Share this post Link to post Share on other sites
ChuckWedel 0 Posted September 11, 2020 Solver, How do I delete the roof plan only under the shed roof? Thanks. Share this post Link to post Share on other sites
solver 621 Posted September 11, 2020 10 minutes ago, ChuckWedel said: How do I delete the roof plan only under the shed roof? See the video -- start watching at 5 minutes in. Share this post Link to post Share on other sites
ChuckWedel 0 Posted September 11, 2020 I figured out how to delete the roof plan below the shed roof, but now I can't get the pitch right on the shed roof, and no walls either. What am I doing wrong? Thanks. Share this post Link to post Share on other sites
ChuckWedel 0 Posted September 11, 2020 Solver / Others, Per the photos attached, this is what I get. There is a shed roof, but when set the height to the height of the rest of the roof, it goes back to 12/12 pitch. The wall are set to full gable walls on the sides and High Shed / Gable Wall on the end. Can anyone help me with this problem? Thanks. Share this post Link to post Share on other sites
solver 621 Posted September 11, 2020 Open one of the outside roof planes and get its ridge height. Open the center roof plane, lock the pitch and enter the ridge height. It should raise up and you should see at least the front wall. Share this post Link to post Share on other sites
ChuckWedel 0 Posted September 12, 2020 Solver, How do you lock the roof plane? Share this post Link to post Share on other sites
solver 621 Posted September 12, 2020 No idea what your version looks like, or if it has these options. Share this post Link to post Share on other sites
ChuckWedel 0 Posted September 12, 2020 Solver, IT WORKED! The buttons don't say 'lock' on them, but they are locked. The wall on the left is there (looking from the front to the back), but no back wall, and no wall on the right. Any ideas on that? THANK YOU! Share this post Link to post Share on other sites
