Stair Railing Question
jrubis
I'm trying to remove a railing from a bottom stair in my plan and don't see any options in the stair properties to do this.
I did find a help article about placing railing manually.
https://www.chiefarchitect.com/support/article/KB-00082/manually-adding-railings-to-a-staircase.html.
I tried this and while it did allow me to place a railing on the desired steps, it had the negative effect of causing the wall below the steps to disappear. If I redraw the wall then the railing disappears. What am I missing?
Thank you, Eric. That was it. But, it now seems that the space under the stairs and the main room are grouped together into one room. I must have something misaligned. I'll work on it a bit and if I can't figure it out I'll attach my plan for more help.
Thanks again.
