TennScott Posted September 3, 2020 Share Posted September 3, 2020 I apparently toggled off all tool bars. I can't figure out how to toggle them back on. I've tried all the function keys and played around with the tools and view options without success. Any suggestions? Also, my cursor has been stuck of Build Terrain. I would like to get back to just the pointer. Feel kinda silly even asking these questions. Link to comment Share on other sites More sharing options...
solver Posted September 3, 2020 Share Posted September 3, 2020 5 minutes ago, TennScott said: I apparently toggled off all tool bars. Sometimes the program does that for you. See Preferences -> Folders to locate your Toolbar folder. Close Pro, then rename the toolbar folder -- to what is not important. Start Pro and it should rebuild the folder -- it keeps a copy just in case ... 8 minutes ago, TennScott said: my cursor has been stuck of Build Terrain Turn on Auto Rebuild Terrain Link to comment Share on other sites More sharing options...
TennScott Posted September 3, 2020 Author Share Posted September 3, 2020 Thanks, I'm in preferences, but did not see a folder specific to tool bars. Link to comment Share on other sites More sharing options...
TennScott Posted September 3, 2020 Author Share Posted September 3, 2020 I ventured further into the All Program Paths and found the files on the screenshot below. I see the User Toolbar folder. Should I rename the backup files or the primary files? Link to comment Share on other sites More sharing options...
solver Posted September 3, 2020 Share Posted September 3, 2020 33 minutes ago, solver said: then rename the toolbar folder The folder, not any files. Link to comment Share on other sites More sharing options...
TennScott Posted September 3, 2020 Author Share Posted September 3, 2020 Renamed folder, restarted, program created a new toolbar folder. Still no menus. I tried opening a plan I made a couple of years ago and still no menus. Somewhere I must have turned something off. I had been turning off Display Options recently which should have no bearing on my problem. Powered the computer off several times and on and still nothing. This screen capture is all I see. Link to comment Share on other sites More sharing options...
solver Posted September 3, 2020 Share Posted September 3, 2020 I'm sure you have toolbars checked. And you can try this. Link to comment Share on other sites More sharing options...
TennScott Posted September 3, 2020 Author Share Posted September 3, 2020 Resetting toolbars worked. Thanks!!!!! Link to comment Share on other sites More sharing options...
