afgrove Posted August 17, 2020 Share Posted August 17, 2020 I've looked in the Q & A section but haven't been able to find an answer to my specific issue. Using HD Pro 2021. I'm building a home with a loft that has a 14 / 12 roof over it and would like to build cabinets built into the very low wall section. If i place cabinets in this area they extend up through the roof. I have tried adding a wall with pass through windows and shelves but then I can't figure out how to attach doors to the front that will open in 3D. Does anyone have a suggestion on how to do this? I'm sure it's been done before. Thanks for your help. Link to comment Share on other sites More sharing options...
solver Posted August 17, 2020 Share Posted August 17, 2020 This only works in Standard View. Make a cabinet with a reduced depth, like 3/4". Change the material as shown. There is also an Opening (no material) material that you may want to experiment with. Link to comment Share on other sites More sharing options...
afgrove Posted August 17, 2020 Author Share Posted August 17, 2020 Thanks Eric, I'll give that a try. Anne Link to comment Share on other sites More sharing options...
