floridauk Posted August 15, 2020 Share Posted August 15, 2020 Sometimes when i move a wall to increase or decrease the room size. the total square footage that displays at the bottom of the floor plan just disappears.....i have been creating a new plan and copying the original one over but it would be a lot easier of i could bring the sf display back....can anyone tell me why it disappears when i move a wall and how to re-display it? thanks Link to comment Share on other sites More sharing options...
davidstvz Posted August 15, 2020 Share Posted August 15, 2020 If it's completely gone because you deleted it, you can make it reappear by running a plan check (you can just cancel the check after starting the process). I had HD interiors 2015 and used it until this year. In that older version, the label will also be moved whenever the house is changed. It's always placed below the lowest part of the house in the center. If you have done what I used to do and marked off the lot and driveway and sidewalks with room dividers, those might be counting as rooms and the label will be moved all the way below those as well. Link to comment Share on other sites More sharing options...
floridauk Posted August 15, 2020 Author Share Posted August 15, 2020 Hmmmm...well, didn't delete it....all i did was push out an exterior wall to add square footage. If i undo it, the ttl sf reappears....it is weird... Link to comment Share on other sites More sharing options...
Rookie65 Posted August 15, 2020 Share Posted August 15, 2020 When you move the wall, is it still connected to another wall to close the area up? If there's an open wall connection, it won't tally the footage. Link to comment Share on other sites More sharing options...
floridauk Posted August 28, 2020 Author Share Posted August 28, 2020 i did know that but no, walls all closed, everything the same....i will just keep re-pasting them in a new plan....it is still happening and i still am lost in space as to why but life istoo short to fret!!! thanks, everyone Link to comment Share on other sites More sharing options...
