TheBMeister Posted July 28, 2020 Share Posted July 28, 2020 Hello, I have a question with regards to general dimensioning in relation to to Room Label dimensions. I have a bathroom sized 5'-0" x 8'-0" (wall structure to wall structure). The dimensions are 5'-0"x8'-0" however the Room label is 1" off, so it is 4'-11" x 7'-11". It seems to measure finish surface to finish surface instead of wall to wall structure. Is there a way to change the room label dimension to reflect that of Wall to Wall structure? See attached image for reference. Thank you Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 29, 2020 Share Posted July 29, 2020 Your visible dimensions are measuring to "Framing Surfaces" and the auto dimension display is pre-programmed to display to finished surfaces. Where the Dimension points of a dimension string determine the display. I commonly turn off that Room Label Display for that reason (I cannot control how it displays dimensions, dimension strings, I CAN control). DJP Link to comment Share on other sites More sharing options...
