azdesigner Posted June 28, 2020 Share Posted June 28, 2020 Can anyone tell me why I have a gap like this in my gable wall? I see the gap in the dotted lines, but I don't know what it means. This is a 1 1/2 story, and when I build the roof first with an 18 inch ceiling, the walls are fine. Then when I go back and raise the ceiling height to the default, I get these gaps. You can see there are two other gaps, also. Here's the view from above. Link to comment Share on other sites More sharing options...
Jo_Ann Posted June 28, 2020 Share Posted June 28, 2020 When you raised the ceiling, it allowed the interior wall to be exposed. Pro has a roof setting to fix that, but Architectural does not. So, you will have to cover it up. Either use a wedge shape from the library, or the custom backsplash tool. 1 Link to comment Share on other sites More sharing options...
