Window mullions
Trueburton
There is a setting in "Edit - Default Settings - Windows - Minimum Spacing" that may help you. It is set "out of the box" to "Two Inches". If you reset the default to "Zero Inches" it is then easier to place windows frame to frame without any "spacing" in between. That setting also effects door spacing as well when you need doors and doors and windows frame to frame.. Take a look please.
