Different surface materials on lower portion of wall
jeffcarp
I had not seen that. I will check it out. I assume that this allows me to define the heights of those wall coverings then? Once I set a wall as I like it can I then apply those same material and covering settings to other existing walls I've drawn or do I have to set each wall manually, separately? Sort of like a "paste formatting" function within Microsoft Excel?
I think only Pro and HDA have Pony walls as a feature , not sure about wall coverings either ,at least in this Article it   suggests once again only Pro and HDA have it as an option
http://www.homedesignersoftware.com/support/article/KB-00891/33/Home-Designer/Walls/Adding-a-Belly-Band-to-Your-House.html
which would mean having to use Soffits  (under cabinet tools)  with a stone material applied and the soffit slid upto the exterior wall
