lyssekelley Posted April 10, 2020 Share Posted April 10, 2020 (edited) I'm trying to build a house that has multiple ceiling heights. Each ceiling height in 9' while one room has 22' ceilings with a 2nd story loft looking down into it. Whenever I connect the walls surrounding the two rooms, one of the walls disappears completely and the middle of the opposite wall disappears in 3D. When I switch to 2D, the wall is still there. Has anyone else run into this problem? I'm brand new to using the program. I'm using Home Designer Suite 2021 I've tried to attached the Plan file but it was too big. Edited April 10, 2020 by lyssekelley Link to comment Share on other sites More sharing options...
solver Posted April 10, 2020 Share Posted April 10, 2020 Someone will need to look at your plan file to answer. Close the program and attach like you did for the image. Link to comment Share on other sites More sharing options...
