editing dimensions
danmor
I have edited dimensions before, but seem to be doing something different now. I created an end to end dimension, then single clicked it, which just selected it. Double clicking opened up a popup diemsion line spec window.
Thanks,
Dan
  • Downvote 1
In WHAT WAY, or what is the reason you need to edit dimensions? Do you wish to edit the dimension points of a dimension string? do you wish to edit the size of the display? Do you wish to change the "arrow" type of dimension strings? Do you wish to display dimensions values in Imperial or Metric or both? Please be specific with your questions so those that wish to help, then can.
