Max-II Posted March 26, 2020 Share Posted March 26, 2020 I'm currently using Home Designer Suite 2021. When I attempt to download the "GE Appliances" from the online "3D Library - Fixtures and Appliances" group, I select "X12 / 2021" and I get the following error (see Error.txt attached). I have made multiple attempts over multiple days, all with the same results. <Erro Link to comment Share on other sites More sharing options...
LawB10 Posted March 26, 2020 Share Posted March 26, 2020 Were you signed into the site before tried downloading? Link to comment Share on other sites More sharing options...
Max-II Posted March 27, 2020 Author Share Posted March 27, 2020 Yes I was signed in at the time. I have realized that the X12 / 2021 version is 0B. If you hover the mouse pointer over the info symbol in the upper left corner of the catalog's image, 'GE Appliances', it shows the sizes of the different versions available and X12/2021 is zero (0 Bytes). Link to comment Share on other sites More sharing options...
LawB10 Posted March 27, 2020 Share Posted March 27, 2020 Unless things have changed, older versions work in newer versions, newer versions will not work in older versions. try downloading the X11 version. Link to comment Share on other sites More sharing options...
