bskinner Posted September 17, 2019 Share Posted September 17, 2019 Before I tried to make a basement everything looked fine. Then I was trying to create a basement and thought I had it and hit save. Silly me didn't look at the full perspective before saving and now I am unable to undo enough to make it revert back to a proper looking house. Can anyone tell me what needs to be changed or what the heck I did wrong? Thanks in advance for your help! Lori Skinner Home Designer Pro 2018 Link to comment Share on other sites More sharing options...
solver Posted September 17, 2019 Share Posted September 17, 2019 You can change the number of times you can undo. Don't know what you did, but if you attach the plan file -- close Pro first, someone will take a look. Link to comment Share on other sites More sharing options...
bskinner Posted September 17, 2019 Author Share Posted September 17, 2019 Thank you for the info Eric. I will upload the plan file. I did spend a bit of time looking through the help files before I posted here. Lauritsen Home Plans - Current.plan Link to comment Share on other sites More sharing options...
solver Posted September 17, 2019 Share Posted September 17, 2019 All your roof planes are at the wrong height and need to be raised. 1 hour ago, bskinner said: Then I was trying to create a basement Creating a basement is a one click operation after setting the defaults. Were you doing something different? Link to comment Share on other sites More sharing options...
bskinner Posted September 17, 2019 Author Share Posted September 17, 2019 Eric, to tell you the truth, I thought I was doing it correctly. I had the reference guide with me. I think I will try deleting the roof and see if that fixes it. Link to comment Share on other sites More sharing options...
bskinner Posted September 17, 2019 Author Share Posted September 17, 2019 Eric, I did go in and delete the current roof and redid a section and it is back to normal. Still not sure what I did wrong in the first place, but I will check the perspective view right after I do anything for sure. Thanks again for your help and suggestions. Link to comment Share on other sites More sharing options...
