447Debbie Posted September 1, 2019 Share Posted September 1, 2019 I want to reduce the width of an entire cabinet by 2" and I want that 2" reduction to come out of a particular section. (Each upper slide out tray in that section can be reduced by 1" each.) How do I do this? The program does not allow me to lock the rest of the cabinet. junk_plan.zip Link to comment Share on other sites More sharing options...
solver Posted September 1, 2019 Share Posted September 1, 2019 Any reason to not use multiple cabinets? Link to comment Share on other sites More sharing options...
447Debbie Posted September 2, 2019 Author Share Posted September 2, 2019 I just didn't want two panels between sections. Multiple cabinets would add the two panels and throw the dimensions off. I guess I could do it that way and make the end panels 1/2 of normal thickness. I'll wait and see. I was trying to size it down for a 10' plywood top, right now it's 10' 2", but if I go solid wood top, I can just leave it at 10' 2". Link to comment Share on other sites More sharing options...
solver Posted September 2, 2019 Share Posted September 2, 2019 I was thinking something like this. Link to comment Share on other sites More sharing options...
447Debbie Posted September 2, 2019 Author Share Posted September 2, 2019 I can certainly create separate cabinets, it would just be a lot of work right now. What I have is pretty custom and sized for the computer stuff I have. It includes pull outs for the keyboards and mice (allowing for left and right handed - since I'm ambidextrous and am forced to use my left hand if my right shoulder acts up). Above the pull outs is empty space just high enough to allow the keyboard and mouse to fit underneath when you push them in. The width in the middle should be enough for two computers and the circulation they will need, plus they sit on a pull out because I'm done with wrestling with computers when you need to do something in the back of them like plug in different cables. Anyway, there is no way to do what I want, so I'll just live with it. I should probably look for a program that is specific for designing cabinetry. Link to comment Share on other sites More sharing options...
