Saloon doors in narrow opening
taltracy
Here is a way to get started:
http://youtu.be/p6jY_z39TeA
PS: I looked for the doors I mentioned in the tutorial but have not found them, But you could just use a doorway (Hole in the wall) and then manually size and place two cabinet doors selected from the library as a secondary solution.
I did find this one that you can try ( I exported it from Chief Architect Premier) attached (You import the library file under "Library" dropdown menu
Princesse Gate.calibz
