AmatuerArchitect Posted August 20, 2019 Share Posted August 20, 2019 Created a wall elevation today for a kitchen and the base cabinets are showing up with red dashed lines, uppers are fine. I've tried moving the camera, the focal point, etc but alas, no difference. Can someone clarify what is happening here? Thanks! Link to comment Share on other sites More sharing options...
solver Posted August 21, 2019 Share Posted August 21, 2019 It's a layer display issue. Open Layer Display Options and search for a layer with a red color and dashed line. Link to comment Share on other sites More sharing options...
AmatuerArchitect Posted August 21, 2019 Author Share Posted August 21, 2019 I figured it would be obvious which edition I was using given Wall Elevation is only available in Pro I believe But yes, I will add it to a signature. I had assumed it was due to a layer issue but only found that color red with dashed in use by Electrical Connections. And I've already searched the forum, Knowledge base, built-in help, PDF manual, and watched the Wall Elevation (and Cross Section) videos looking for comments Link to comment Share on other sites More sharing options...
solver Posted August 21, 2019 Share Posted August 21, 2019 40 minutes ago, AmatuerArchitect said: I had assumed it was due to a layer issue but only found that color red with dashed in use by Electrical Connections. Did you check the layers while in the Wall Elevation view? This is Premier, but shows using a layer set normally used for plan view in a wall elevation view. Link to comment Share on other sites More sharing options...
AmatuerArchitect Posted August 21, 2019 Author Share Posted August 21, 2019 Hi Eric, Yes I was checking in the Wall Elevation view AND I'm evidently color blind as the color it the layer setting and in the wall elevation don't look the same to me Thanks for you help, shoulda looked under Cabinets vs scrolling through the whole list looking for red! Link to comment Share on other sites More sharing options...
