tgidave Posted August 14, 2019 Share Posted August 14, 2019 Hi All, I just upgraded to Home Designer Pro 2020 but I don't think that is a part of this problem. I am designing and building a small 12x16 shed with 8' walls. Everything went well until I decided to put a garage door on one side. When I added the door it defaulted to a 9x8 door and increased the wall height to 9'. I then changed the door size to 9x7 hoping that the wall size would revert to 8' again. No such luck. I can not find a way to change the wall height. I'm sure I'm just overlooking some field in some setting screen but any help would be appreciated. Thanks in advance, Dave Link to comment Share on other sites More sharing options...
solver Posted August 14, 2019 Share Posted August 14, 2019 Please update your signature. 48 minutes ago, tgidave said: When I added the door it defaulted to a 9x8 door and increased the wall height to 9'. That's not the way the program works. Here is a structure with 8' walls and the default 8' garage door. My guess is you drew your shed with 9' walls. Open the room, on the Structure panel, set the ceiling height to be whatever you want. Or, even better, open Defaults, set the ceiling height, then and rooms you create will be correct. 1 Link to comment Share on other sites More sharing options...
tgidave Posted August 14, 2019 Author Share Posted August 14, 2019 Yup, the ceiling height was set to 109 1/8. I was looking for a wall height field instead of a ceiling height field which was most of the confusion on my part. I will know better in the future. Thank you!!! Dave Link to comment Share on other sites More sharing options...
