MississippiMims Posted August 13, 2019 Share Posted August 13, 2019 I am trying to build a small covered porch or stoop in the area in front of the front door of my plan. When I try to add a room using invisible rails it wont incorporate a slab. When I try adding an invisible wall, the slab keeps the existing brick ledge instead of incorporating with the new room. I also would like to bring the porch out a foot or two from the front bedroom wall as an accent. I would like some advise on how to make the roof extend from the ridge of the garage structure to cover the new porch. Link to comment Share on other sites More sharing options...
solver Posted August 13, 2019 Share Posted August 13, 2019 Make your porch room using room divider walls. Use railing walls when you want railings. And for the best help, attach your plan file. A picture of the plan rarely helps. Link to comment Share on other sites More sharing options...
MississippiMims Posted August 13, 2019 Author Share Posted August 13, 2019 Thanks for the advise. I'll give it a try. Link to comment Share on other sites More sharing options...
