Telepost
LesVJohnson
Can anyone tell me how to locate a non-movable object such as a telepost or support column hidden in a wall on a drawing.  I want to be able to modify some non load walls without continually checking the dimension with respect to these teleposts.
Home Suite 2020
Thanks in advance
Les
I don't understand what you are trying to do.
What do you want to locate? Locate how?
What is causing you to "continually check the dimension".
How can insert a telepost and then build an interior wall around/inside it.  I am drafting an existing plan where the support structure is already in place.  So now that I am working options for changing the floor plan and leaving the existing support structure untouched.
Does this make sense?   I would like to see the location of these posts on the drawing as its own element that I can dimension to.
