covetkitchens Posted April 23, 2019 Share Posted April 23, 2019 Hi, Is there a title block template available for Home Designer Pro? I have a created a new layout and a message comes up noting that I can not use the Chief Architect template. Thanks Link to comment Share on other sites More sharing options...
solver Posted April 23, 2019 Share Posted April 23, 2019 I don't understand "title block template", or how anything related to Chief Architect fits with your question. What are you doing/trying to do? Link to comment Share on other sites More sharing options...
covetkitchens Posted April 24, 2019 Author Share Posted April 24, 2019 I would like to create layout /blueprints from my plan drawing. Usually there is a template title block or a border available when you create a layout, see link below to help explain title block. http://www.helmettown.com/26-images-of-cad-title-block-templates-download_6009/ Hope this helps. Link to comment Share on other sites More sharing options...
solver Posted April 24, 2019 Share Posted April 24, 2019 10 minutes ago, covetkitchens said: Usually there is a template title block or a border available when you create a layout The default layout has one. It looks like this. What do you see? Link to comment Share on other sites More sharing options...
covetkitchens Posted April 24, 2019 Author Share Posted April 24, 2019 This is what I see, message reads: c:\p4sync\dev\releases\21.1\chief\source\documentfactory.cpp(337): Warning #272011639 "The template plan "C:/Users/Pinky/Documents/Home Designer Pro 2020 Data/Templates/ProfileM.layout" was created by a professional version of Chief Architect. You cannot use this plan as a template. A new plan will be created without using a template." 4/24/2019 10:31:47 AM Build: 21.1.1.2x64 Link to comment Share on other sites More sharing options...
solver Posted April 24, 2019 Share Posted April 24, 2019 1 hour ago, covetkitchens said: I have a created a new layout You are creating a plan. A layout is different, and where you would find a title block as per my image above. Suggest you work through the Tutorial found under Help to get an understanding of how the program works. As for your problem, you probably need to contact Support via the website, but try this first. Close Pro. Rename the Templates directory. Start Pro. It will create a new Templates directory from its backup. Start a new plan to test. Link to comment Share on other sites More sharing options...
covetkitchens Posted April 24, 2019 Author Share Posted April 24, 2019 Thank you Solver. I was able to open the title block successfully directly from the templates folder. Link to comment Share on other sites More sharing options...
