Je_Roy Posted April 16, 2019 Share Posted April 16, 2019 I am using HD-Arch 2016. Angling the top edge of a window is very easy with the 'match roof' shape option. But the bottom edge remains flat in line with the floor. As you can see in the attached elevation view, I have an angled wall section that overlooks a roof plane that the cursor is on. I have created a window on this wall, but it is not taking on the desired shape. How can I modify this window so that the bottom edge is also angled? TYIA Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 16, 2019 Share Posted April 16, 2019 The attached image was done with my trial copy of Home Designer Pro 2020. I tried to do the same thing in Architectural 2019 and the necessary controls in the dialog were missing in Architectural, sorry. An upgrade to Pro is what you must do or just do without. DJP 1 Link to comment Share on other sites More sharing options...
Je_Roy Posted April 16, 2019 Author Share Posted April 16, 2019 Thank you! I am planning to upgrade and Pro seems most worthwhile for the cost. Anything with varying angles or depths is far too annoying in Architectural Link to comment Share on other sites More sharing options...
