MAndrews Posted November 15, 2014 Share Posted November 15, 2014 Is there a way to make a custom layer - and assign objects to be on that layer? Trying to separate some electrical objects - High-voltage from low voltage - and use different colors for each. I'm using 2015 Pro. Thanks! Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 15, 2014 Share Posted November 15, 2014 That is something you get with Chief Architect Premier only. DJP 1 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted November 15, 2014 Share Posted November 15, 2014 HD titles only have one layer , so the only workaround is to make copy's of you plan with different names eg My House - LVoltage , My House - H.Voltage etc and then do that work in each plan and print it out as needed , you just have to keep track of changes which is the downside to this workaround but if you do it after all the design work is done right before doing construction docs it works. Mick. Link to comment Share on other sites More sharing options...
Solution Elovia Posted November 15, 2014 Solution Share Posted November 15, 2014 Another choice would be that you may assign custom labels to the HV or LV components. Good luck. Link to comment Share on other sites More sharing options...
MAndrews Posted November 15, 2014 Author Share Posted November 15, 2014 Thanks for all the responses! Link to comment Share on other sites More sharing options...
