jrubis Posted April 7, 2019 Share Posted April 7, 2019 Hi. I need some help in adjusting the attached plan. I want to finish a room above the garage, but I obviously have something screwed up with the structure of the garage. The floor of this room should be level with the 2nd floor of the house, but it's not. The room should have knee walls that are about four feet high on either side and the floor should be level with the floor on the 2nd story of the home. Can some adjust my plan or let me know what I need to do to get it right? HomePlan3D.zip Link to comment Share on other sites More sharing options...
solver Posted April 7, 2019 Share Posted April 7, 2019 Open the room, change the floor height to match. Link to comment Share on other sites More sharing options...
jrubis Posted April 7, 2019 Author Share Posted April 7, 2019 I tried that...The software doesn’t view that space as a room. Link to comment Share on other sites More sharing options...
solver Posted April 7, 2019 Share Posted April 7, 2019 1 minute ago, jrubis said: The software doesn’t view that space as a room. That's a problem You need a 2nd floor, you cannot create a room on the A (attic) floor. Check walls to make sure none have No Room Definition checked. Link to comment Share on other sites More sharing options...
jrubis Posted April 8, 2019 Author Share Posted April 8, 2019 OK, that worked. Thanks. It turns out the front gable wall was set for "No Room Definition". Knee walls were OK. How do I break the wall along the roof line of the gable to prevent the interior wall definition from extending out past the gable? See attached pic. Also is it possible to do a "doll house" view into this room? If I set the view to the second story it just shows the roof. If I set it to the first story it shows the garage. Link to comment Share on other sites More sharing options...
YankeeBob Posted April 11, 2019 Share Posted April 11, 2019 I suspect that if you go into the dollhouse view and then go to the tools, display options menu you can just turn off the roof planes, ridge, etc. to see whats under the roof. I'm fairly new at this so I could be wrong. This works in my Pro 2020 version but I think it will work for you as well. Link to comment Share on other sites More sharing options...
jrubis Posted April 11, 2019 Author Share Posted April 11, 2019 Thanks that worked. Link to comment Share on other sites More sharing options...
