Double Dimensions of Floor Plan
PDSlax
Hi there. I’m trying to create a model of a school building floor plan for a colleague, and I made the mistake of creating it at a scale where one foot in the application is equal to two feet in the actual building. I drew up the initial plan just fine, but when I added windows, doors, etc., things went awry. Is there a way I can either double the size of the existing floor plan or reduce the size of doors, windows, openings, furnishings, and so on? It would be awesome  if there were a way to simply double the size of the  basic layout.
Any suggestions?
How did you do that?
The drawing is always 1 to 1, and gets scaled when printed.
No to both.
I didn't set up the application for that scale; instead I just used that scale informally. That is to say, when my colleague described a room that is 20' by 30', my plan for that room in Home Designer Suite was 10' by 15'. I thought this would give the app less data to manage and reduce the lagginess that happens when the plan gets more and more complex.
In any case, I have simply redrawn the floor plan at a regular 1:1 scale. I wanted to reply to your posts to thank you for writing back to me and to make sure that my signature showed which version of Home Designer I'm using.
Thanks!
