Wedge shaped stairs
MrsBearshark
Is there a way to cut one side of a flight of stairs at an angle?  My design includes a 15 degree rotation between 2 volumes, and I'd like a straight run of stairs to connect, but follow the 2 different angles.  I've checked the knowledge base, but all I can find is information on how to create winders, which is not exactly what I'm trying to do. All the treads will have the same depth, but one side will be cut at a 15 degree angle.  See attached image. I'd like the side of the stairs at the top of the image to follow the angle of the wall next to it, while the side of the stairs in the bottom of the image remains where it is.
Thanks!
Using Home Designer Pro 2019 on a Macbook Pro
