Huckleberry 0 Posted March 14, 2019 I am learning how to use home designer pro for a bedroom addition. I am wanting to extend a gable out to accommodate the addition but on a slab instead of on a footing with a stem wall. I was able to do this and get the roof offset to a lower level as I wanted but, the stem walls seem to change through out the house when I change the addition room. Existing home is on footings with a stem wall, I want the addition at a slightly lower level, roof included, for a better look and so we walk straight out into the yard for this room close to ground level. Any help would be appreciated. Share this post Link to post Share on other sites
solver 630 Posted March 14, 2019 I see you said Pro, but you can help everyone by adding this info to your signature (see below for how to turn them on, then see mine for an example) by clicking on your user name at the top right of the page, click Account Settings, then Signature on the left. Be sure to include the year (2018, 2019 etc). Doing so makes it always available, and keeps others from having to hunt for it. And, turn on signature display too. ---- Resources for self help: The built in Help System (always a good place to start) Getting Started Knowledge Base YouTube Share this post Link to post Share on other sites
solver 630 Posted March 14, 2019 Check Monolithic Slab in the new room, rebuild the foundation. Share this post Link to post Share on other sites
Huckleberry 0 Posted March 14, 2019 I selected the new room clicked the monolithic slab but when I change the stem wall heights, they change through out the structure, new room and existing. Share this post Link to post Share on other sites
solver 630 Posted March 14, 2019 Post the plan file -- close pro first. Share this post Link to post Share on other sites
Huckleberry 0 Posted March 14, 2019 Sorry, I do not know how to post the plan file. Drag a copy of my saved file after closing Pro? Thank you for your help. Share this post Link to post Share on other sites
Huckleberry 0 Posted March 14, 2019 Addition is labeled Master Bedroom. ADDITION FLOOR PLAN copy.plan Share this post Link to post Share on other sites
solver 630 Posted March 14, 2019 I should have said, delete the foundation, then rebuild. Share this post Link to post Share on other sites
Huckleberry 0 Posted March 14, 2019 OK, great thank you. How do I get the slab lower where the footings match but floors are offset about 24 inches? Share this post Link to post Share on other sites
solver 630 Posted March 14, 2019 Watch on YouTube: http://youtu.be/wJ6K4Ts3Des?hd=1 Share this post Link to post Share on other sites
Huckleberry 0 Posted March 14, 2019 That was it, thank you very much for the help. I will need to show attachment of the slab to existing foundation. I guess I can just draw that. Share this post Link to post Share on other sites
