Orionfe Posted March 6, 2019 Share Posted March 6, 2019 Hi all, I uploaded a screenshot of the curved stairs I designed and I'm looking for a couple of things. 1. the radius angle / length of each stringer 2. The rise & run layout marks for each stringer as obviously these change from stringer to stringer. I will not have the space to lay it out manually on the floor as this is a remodel with no room to do that so I plan on doing the layout (stringer layout framework / forms) at work with a trammel board and plywood to build the form arc pieces Forgive my ignorance as this software is new to me. Thank you, Bill Link to comment Share on other sites More sharing options...
solver Posted March 6, 2019 Share Posted March 6, 2019 What is "radius angle"? Link to comment Share on other sites More sharing options...
Orionfe Posted March 6, 2019 Author Share Posted March 6, 2019 The radius angle would be the angle of the radius of the inside stringer and the outside stringer Link to comment Share on other sites More sharing options...
Orionfe Posted March 6, 2019 Author Share Posted March 6, 2019 My terminology may be incorrect Link to comment Share on other sites More sharing options...
solver Posted March 6, 2019 Share Posted March 6, 2019 Can you say what measurement you need? Radius is a linear measurement, there is no angle involved. What angle do you need? I'd want the length of the red lines for each segment. Knowing the dimension of the tread you should have all you need to do the layout. Link to comment Share on other sites More sharing options...
Orionfe Posted March 6, 2019 Author Share Posted March 6, 2019 Yes you would be correct. That would give me the location of the treads but not the depth on the outside stringer or the inside one. That being the risers should stay the same at 7 5/16 on either stringer correct. This pic is shown with the walk line 12" in from the edge Link to comment Share on other sites More sharing options...
Orionfe Posted March 6, 2019 Author Share Posted March 6, 2019 The treads are 40" long and obviously tapered Link to comment Share on other sites More sharing options...
solver Posted March 6, 2019 Share Posted March 6, 2019 You should be able to take a measurement at any of the green lines. Turn off the hand rail display. Link to comment Share on other sites More sharing options...
Orionfe Posted March 6, 2019 Author Share Posted March 6, 2019 Yea you're right. Let me work on this a little more...thank you!!!!! Link to comment Share on other sites More sharing options...
