Home Designer Pro 2019 is shrinking exterior rooms
mdavis0698
I am using Home Designer Pro 2019.  When I first started a space plan and told it to "Build House" the exterior walls pushed outwards and maintained the exterior room sizes.  However, I have a current space plan that is shrinking all exterior rooms by 3" to 3.5" each side and causing misalignment with interior walls (I discovered they actually vary).  Is there a default setting that I may have chosen that is causing it?  I have checked EVERYTHING in the manual about defaults and cannot find a reason this may occur.  I have tried changing every setting that I can think of to be the culprit setting, but have been unable to find it.  Please help.
