vhehn462 Posted November 4, 2014 Share Posted November 4, 2014 got a plan drawn but want the walls to be stacked stone in the elevation view. no matter what I try it will not change. have tried to change it in defaults and by opening an individual wall object and specifying stacked stone. nothing works. any ideas? Link to comment Share on other sites More sharing options...
solver Posted November 4, 2014 Share Posted November 4, 2014 Like this? Link to comment Share on other sites More sharing options...
katalyst777 Posted November 4, 2014 Share Posted November 4, 2014 Which version of the software are you using?Is it just walls you are having trouble changing the material on? Link to comment Share on other sites More sharing options...
vhehn462 Posted November 5, 2014 Author Share Posted November 5, 2014 using 2015 version. I have bigger problems now. after screwing around trying to get the walls to change to stacked stone I closed the program and now when I open it I have just two lines on my buildsheet. a random straight interior wall and a straight section of exterior wall. nothing else. my whole plan seems to be gone. where did it go? if I do an elevation from the edge of the page the elevation view is still there. confused? what did I do wrong? Link to comment Share on other sites More sharing options...
Kbird1 Posted November 5, 2014 Share Posted November 5, 2014 post your version of HD 2015 and a copy of your plan so someone can look at it for you. if you have really screwed the plan up somehow , look in the Data Folder for a folder call archives and look for a plan with the same name as the one that went pear shaped.... M. 2 Link to comment Share on other sites More sharing options...
vhehn462 Posted November 5, 2014 Author Share Posted November 5, 2014 here is my plan. appreciate it if someone can tell me what caused the plan to disappear. tia vhehnplanonbaneberryloop.plan Link to comment Share on other sites More sharing options...
vhehn462 Posted November 5, 2014 Author Share Posted November 5, 2014 Like this? hi the stone I am trying to use is under home designer core catalog,materials,masonary&stone,stone,stacked stone. Link to comment Share on other sites More sharing options...
katalyst777 Posted November 5, 2014 Share Posted November 5, 2014 After looking at the plan, solver called it, you have Floor A active, go back down to Floor 1. Link to comment Share on other sites More sharing options...
vhehn462 Posted November 6, 2014 Author Share Posted November 6, 2014 After looking at the plan, solver called it, you have Floor A active, go back down to Floor 1. ok that worked thank you. still cant get wall covering to change to stacked stone in the elevation view trying everything suggested. Link to comment Share on other sites More sharing options...
vhehn462 Posted November 6, 2014 Author Share Posted November 6, 2014 That is the stacked stone from the core catalog in an elevation. Here it is from a 3D view. Applied in the Wall Specification > Wall Covering Make sure you are applying to the exterior surface. You could also paint it on with the material painter, or create a new wall type with the stone as the exterior material. none of the suggestions would change my exterior wall to stacked stone. I know it should but cant figure out why it refuses to change. Link to comment Share on other sites More sharing options...
vhehn462 Posted November 6, 2014 Author Share Posted November 6, 2014 I opened your plan and here is what I found -- stacked stone everywhere except some wood at the slab/foundation level. Are you seeing something different? ok I see. under 3d camera view I get the stacked stone but under elevation camera view no stacked stone. is that normal? another question if you don't mind. why does the wall look invisible inside the porch? tia Link to comment Share on other sites More sharing options...
