RobinD Posted January 26, 2019 Share Posted January 26, 2019 In Suite 2019 is it possible to change an interior wall height within a room? For example I have a walk in shower and I'm trying to set the wall height at 7'. The rest of the walls are at 9'. As you know, in 3-D when you try to modify one walls height all the walls follow. Link to comment Share on other sites More sharing options...
RobinD Posted January 26, 2019 Author Share Posted January 26, 2019 Not seeing it in the help index.... Link to comment Share on other sites More sharing options...
RobinD Posted January 26, 2019 Author Share Posted January 26, 2019 Looked a little closer and found shelf ceiling. Doesn't really apply here. I just simply want to know if it is possible to highlight a wall and change its height. Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 26, 2019 Share Posted January 26, 2019 She said in her first post "Suite 2019" Eric. DJP Link to comment Share on other sites More sharing options...
RobinD Posted January 26, 2019 Author Share Posted January 26, 2019 Is he the signature police? Yes, I already posted what version I'm using. So-does anyone have an answer? I may have confused the question by not mentioning I don't want a ceiling over the shower with the shorter walls. This allows me to use one exhaust fan. Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 26, 2019 Share Posted January 26, 2019 Suite does not have the ability to adjust single walls as does Architectural and Home Designer Pro. The only way I know of is to make the walls, you want shorter into solid railing walls. I suppose you could make those solid railing walls from glass shower walls, set to solid railings and thus control their height by way of the Newells and Balusters tab (I have never tried this myself, I have Chief Premier, so I do not have to). I will try this with my copy of Suite 2019 and get back to you here. DJP Link to comment Share on other sites More sharing options...
RobinD Posted January 26, 2019 Author Share Posted January 26, 2019 Thanks for your time. No need to try. I'll experiment on my own. I'm probably going to use the soffit tool or just let it ride. Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 26, 2019 Share Posted January 26, 2019 DJP Link to comment Share on other sites More sharing options...
RobinD Posted January 27, 2019 Author Share Posted January 27, 2019 Thanks David....Nicely done. I was just going to create shower walls using the soffit tool and put a door opening in one wall. Quick, easy and close enough. I appreciate your time. Link to comment Share on other sites More sharing options...
