WayneVC Posted January 15, 2019 Share Posted January 15, 2019 Is there a way that I can create a terrain and then place different plans on it in Architectural? Link to comment Share on other sites More sharing options...
solver Posted January 15, 2019 Share Posted January 15, 2019 You could create a terrain only in a plan, make copies of the plan and add different houses to each. Link to comment Share on other sites More sharing options...
WayneVC Posted January 15, 2019 Author Share Posted January 15, 2019 Eric, Thanks for helping a newbie! I have fixed my signature settings. WRT your good suggestion: is there a way to then either import one of the copies into an existing plan that does not have a terrain defined or, alternatively, copy a plan into the terrain plan. I have several different design variants and I don't want to have to redraw each one into a site plan. Wayne Link to comment Share on other sites More sharing options...
solver Posted January 15, 2019 Share Posted January 15, 2019 It may be as simple as a copy/paste operation. Research Edit Area. Also Paste/Hold Position. Link to comment Share on other sites More sharing options...
WayneVC Posted January 16, 2019 Author Share Posted January 16, 2019 Thanks, Getting there, slow but sure. The answer does seem to be Edit Area, then a copy/paste sequence. I have to figure out how to position and scale the two objects in advance, as they (obviously) become part of the same plan once the paste occurs and are no longer simple objects that can be independently moved /scaled. Link to comment Share on other sites More sharing options...
