Framing Help
ncochran
Hello,
I have multiple issues with the framing build. Let's start with the floating members. The rafters are floating and a gap remains between the wall and roof in sections. Ceiling joists are floating. How do I correct this?
I also have areas with missing rafters or joists. The junction of the main roof to the porch roof is just an overlap, and much more.. Any help that can be provided is appreciated.
FarmHouse Help.plan.zip
All framing is capable of manual editing. That is what manual framing tools are for. You set Default Settings - Framing to as close as is possible to your desires, built framing and then edit manually to suit. The software is a semi-automated tool but in the end, it is you who does the drawing.
