"Explode" Auto Floating Dormer?
SeabeeMike
Thanks to some great help from the Forum (thanks David J Potter!!), I've lost my fear of manual roofs and, quite frankly, haven't missed Auto Roof whatsoever!
I have to admit I started out making this Gable element over the porch by manually adding the wall on the second floor, building a couple roof planes & setting everything up.  Only struggle was not being able to cut a "hole" in the main roof.  At that point, I decided to try the Auto Floating Dormer.  From what you can see, I have a 95% solution.  My only challenge is that the face of the fascia on the dormer roof should continue all the way down to the main roof rather than having a small piece of eave - see example.
I presumed I could manually manipulate the roof of the dormer to fix this but no luck.  Easy fix, such as Explode the dormer, or more challenging?
Thanks!
Villa Sogno - Dormer Test.plan
Edited by SeabeeMike
Typo
What was the issue?
Pro has that ability.
Explode the dormer -- drag walls as needed.
