Olivier Posted November 30, 2018 Share Posted November 30, 2018 Hello, I need to build a new terrain from a JPEG, so I import Backdrop. Size of terrain dimension is not the right one, so I increase the picture size by X percent, and try again. Even with a biggest terrain's image, size remains the same in HDPro. Question: How to increase terrain size by X Percent? Thank you for your help :) Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 30, 2018 Share Posted November 30, 2018 Some of what is in the video is relevant only to Chief Premier but at least 90% is directly relevant to Home Designer Pro. You have not indicated exactly which HD Title you actually have but this should help generally DJP Link to comment Share on other sites More sharing options...
Olivier Posted November 30, 2018 Author Share Posted November 30, 2018 Thank you so much David Link to comment Share on other sites More sharing options...
