JamesG2018 0 Posted November 23, 2018 Is there a tool or a way of easily seeing the total square footage of the house plan? I see there is a way to display the area of the rooms in the labels, but I can't find a way to see the total area of the whole plan. Share this post Link to post Share on other sites
solver 630 Posted November 23, 2018 You can only show total area per floor. Is your Living Area Label showing? A search within the Help system should tell you about it. Share this post Link to post Share on other sites
JamesG2018 0 Posted November 24, 2018 The Living Area Label is not showing. I found a reference to the area label, in the Help System, but it won't turn on the label. Share this post Link to post Share on other sites
JamesG2018 0 Posted November 24, 2018 This is the dialogue I found to turn on and off the Living Area, but it doesn't have any effect on the label. Share this post Link to post Share on other sites
solver 630 Posted November 24, 2018 Run a Plan Check. Tools>Checks>Plan Check (may be different in Suite). You can ignore any/all warnings. 1 Share this post Link to post Share on other sites
JamesG2018 0 Posted November 24, 2018 That did the trick. Thank you! Share this post Link to post Share on other sites
