Sign in to follow this
447Debbie
Closet changes room specifications
UPDATED:  I got this to work by drawing my closet, then going to room specification and checking the default boxes.  I'm not sure why I couldn't achieve the same thing by actually entering the default values.
I'm trying to create a closet in a lower level (0) bedroom.  Why is the program changing my absolute elevations and relative heights?  See attached picture.  I've done nothing other than draw in the closet walls and for some reason the absolute elevations and relative heights on the newly drawn closet are different than the room in which it was created.
Edited by 447Debbie
It may be picking up the default room heights from floor 1. Simplest way I have found around these things is to leave the room type as the floor is & just change the room name to display what you want it to be called. Saves a lot of hair pulling . . .
