johnlou Posted October 18, 2014 Share Posted October 18, 2014 Hello, I'm new to this forum and use Home Designer Architectural 2015 with the latest updates. I searched the forum for dishwasher and there are no results. I'm designing a basement floor plan with a small kitchen. I would like to place a dishwasher with width of 18-inches instead of the standard width of 24-inches. I can place one of the library dishwasher objects as a face to a cabinet. I can change the width of the cabinet but not the dishwasher face which is fixed at 24-inches. Please advise. Best regards, John Link to comment Share on other sites More sharing options...
Kbird1 Posted October 18, 2014 Share Posted October 18, 2014 you may need to find and import a 18" dishwasher on 3D Warehouse if the library symbols can't be resized to 18". An alternative would be to use the library 18" Trash Compactor and just label it DW instead. Mick. Link to comment Share on other sites More sharing options...
johnlou Posted October 18, 2014 Author Share Posted October 18, 2014 Kbird1, Thank you for the advise. Best regards, John Link to comment Share on other sites More sharing options...
DavidJPotter Posted October 19, 2014 Share Posted October 19, 2014 Use a trash compactor and then call it a Dishwasher, no one can tell the difference at a glance. DJP Link to comment Share on other sites More sharing options...
katalyst777 Posted October 22, 2014 Share Posted October 22, 2014 Or, you can place the Dishwasher as a standalone object (you'll get a message indicating it's designed to be placed in a cabinet, place it anyway), once it is resized in your plan, add it to your User Library at the new 18" size. Then you can add the modified Dishwasher in to a cabinet from there. 2 Link to comment Share on other sites More sharing options...
Kbird1 Posted October 23, 2014 Share Posted October 23, 2014 Nice tip Kat777 , have you tried this with a Dishwasher ? as I can't get it into a 18" cabinet after resizing it even down to 16" , tried adding to library after resizing but still wont insert in either Pro 10 or Pro 2015. M. Link to comment Share on other sites More sharing options...
katalyst777 Posted October 27, 2014 Share Posted October 27, 2014 Yes, I used the Dishwasher (control panel) symbol, but it should work with any of the appliance fixtures that are designed to be places inside of a cabinet. Link to comment Share on other sites More sharing options...
Kbird1 Posted October 28, 2014 Share Posted October 28, 2014 thanks for the followup , I will try again , the resizing isn't an issue with the intergrated 2 dishwasher , so I maybe doing something else wrong... Link to comment Share on other sites More sharing options...
Kbird1 Posted October 29, 2014 Share Posted October 29, 2014 It seems that you can't immediately ( at least for me) change the size of the dishwasher ,add it to the library, then try to place it back in the same plan . If I created a new plan and added a cabinet the new 18" dishwasher went in fine , same as if I closed the original plan , reopened it then inserted the new 18" dishwasher it worked fine. perhaps opening and closing the library would have worked too after adding it to the library? so the library updated itself ? note I made the dishwasher 17 11/16" , since the original 24" one was 23 11/16. Thanks again for the tip.... Mick. Link to comment Share on other sites More sharing options...
