How Do I place a separate Roof Over Porch
FLAAustin
I'm learning this product and am a bit slow, especially when it comes to roofs, etc.
This is a two story house we are working on building, currently it is over the 3000 sqft
max living space (building cost constraints).  The bottom floor is 10' and second is meant to
be 8'.  The roofs are 12:12.  Looking to add a shed roof  at the level of the 2nd floor joists to
go over the porch.  It would be in the range of 3 or 4:12 pitch.
Any hints on how I create a shed roof to go over the front porch and attach to the building?
Thanks in advance for any pointers.
Also I realized I should attempt to put this in a proper part of the Home Talk for Hints and Tips but didn't see how to do that.
Sorry....
Answers often depend on which title (Suite, Pro etc) and version (2018, 2019 etc) you are using.
You can help everyone by adding this info to your signature (see mine for an example) by clicking on your user name at the top right of the page, click Account Settings, then Signature on the left.
Doing so makes it always available, and keeps others from having to hunt for it.
And, turn on signature display too.
Resources for self help:
Eric thanks for these housekeeping tips.
The porch concrete was arbitrarily added to the slab with a non-specific thickness and offset from the main house slab;
did that in 3D view and dragged to get it in place roughly.
Still looking to figure out how to define those relative dimensions properly.  Also, placed an 'invisible wall' (3 sides only) around the
perimeter of the porch slab.  I'll go back and try 4 sides invisible and see if a 'room' can be defined.
Thanks
Delete the slab and walls.
All you should need are 3 invisible walls outlining the porch. Set the room type to Porch and make sure Roof Over is checked.
Set the end walls to Full Gable and the front wall to have a lower pitch.
Eric, thanks for this info, however I'm having issues with ensuring the porch roof is at the proper
elevation over the porch slab, as well as having a ~6" drop from the main floor slab to the porch
slab.  I realize the tools are likely there, but I just need to beat around in the program some more
to get the slab heights, main floor and porch, to be at the correct relative locations.
Will keep working on it.
Thanks for your help and suggestions.
Frank
