Chen12 Posted June 15, 2018 Share Posted June 15, 2018 Hi, now I have Home Designer Pro Trail and can make construction drawings with NEW LAYOUT and SEND TO LAYOUT. But only horizontal on floor plan level. 1) How can I make vertical construction drawings (parallel to the walls)? 2) How can I move the horizontal construction drawing position up or down? Thanks. Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 15, 2018 Share Posted June 15, 2018 Every application that Home Designer makes has lots of dialog boxes that control that tool's attributes. The layout is not different. look under "File - Print - Drawing Sheet Setup - Orientation -Portrait or Landscape". DJP Link to comment Share on other sites More sharing options...
Chen12 Posted June 16, 2018 Author Share Posted June 16, 2018 That's for horizontal and vertical Drawings. Thank you! For my deck I get a horizontal floor plan in the height of the decking. OK. But there are also below the decking e.g.posts and concrete footer. When I switch one floor deeper they disappear. How can I get these post and footers on a drawing? Thanks for your help. Link to comment Share on other sites More sharing options...
