SchneiderIS Posted June 10, 2018 Share Posted June 10, 2018 I have a pony wall (split wall) that tI am using for a garage. Basically I have the wall type set for a split wall with the lower split being a concrete stem wall for 5 1/2" and then I do a traditional 2x6 wall for the other part of the split. When I go to doing any sort of framing view though I cannot find a way to show the concrete stem wall. This causes the building to look like it is floating in space for Layouts. I have searched online and watched several videos but cannot find anything around this. What I do know is that if I keep "Walls - Normal" on for display I see the stem, but I see everything as a solid and that includes the drywall and sheathing. Home Designer Pro 2018. -Peter Link to comment Share on other sites More sharing options...
solver Posted June 10, 2018 Share Posted June 10, 2018 You can draw in a stem wall using the slab tool. In an elevation, you can add CAD work to show the stem wall. Changing the wall definition also works. Here I made everything except the main layer for the upper wall Opening No Material. Don't use a Framing Overview for this. Link to comment Share on other sites More sharing options...
